cynthy10's Avatar
Send a message via AIM to cynthy10
Porsche Crest wheel hop on hard acc.
early 85 944 5speed .If I acc. hard from a dead stop or hit 2ed hard rear wheel hops bad is this normal ?
Old 05-11-2003, 02:23 PM
Send a message via AIM to TheCooler
hops? ....dont be chirpin the tires son. Its not good for the tranny.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 05-11-2003, 02:57 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
I used to get it with my old tires... New tires fixed it. What are you using for rubber?
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 05-11-2003, 03:47 PM
cynthy10's Avatar
my tires are 215-60r15 bridgestone potenza with 70% tread left
Old 05-11-2003, 07:04 PM
which model of potenza...speed rating?
Old 05-11-2003, 08:31 PM
Roger Hall's Avatar
Re: Re: wheel hop on hard acc.
Originally posted by FR Wilk
You need new shocks?
FR Wilk
http://frwilk.com/944dme
http://frwilk.com/early944
email: motronic@frwilk.com
________________________________________________
_
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 05-11-2003, 08:38 PM
cynthy10's Avatar
CHEESEY!
Old 05-11-2003, 10:23 PM
cynthy10's Avatar
R.HALL ANY SEGUSTONS?
Old 05-11-2003, 10:25 PM
AFJuvat's Avatar
You need new shocks
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-12-2003, 05:04 AM
cynthy10's Avatar
THANKS FOR THE INPUT.
Old 05-12-2003, 06:02 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Wheel hop? If I understand this correctly it only happens during hard launches? My turbo suffers this to some extent, but it's not bad once out of 1st. It's caused by looseness in the rear suspension, more specifically stub axles, cv joints, and output shafts on the transaxle. Shocks may help to a degree, but they won't cause it.
Ahmet
Cheers!
Old 05-12-2003, 06:13 PM
Roger Hall's Avatar
Originally posted by AFJuvat
You need new shocks
AFJuvat
Suggestion is listen to FR and AF. You need new shocks.
Why Cheesey?
Roger Hall
81 924 N/A
Old 05-12-2003, 06:28 PM
you could wait and do the shocks when you replace the transmission
cheesey?
Tom
Early '85 944
Old 05-12-2003, 06:46 PM
Ornery Bastard
For your transaxle's sake, I hope your car has the rubber-centered clutch. That way the clutch center will grenade before the transmission.
Seriously, Porsche transmissions during the 1970's and 1980's are definitely not known for tolerating severe launches and shifts well at all. 914's have been known to shear off first gear, 924's/944's/924S's have been known to blow synchros. Bottom line, go gentle on that transaxle, the car is built for touring, not for acceleration runs. If you want to drag race, get a pony-car, it will be both faster and more reliable.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 05-12-2003, 09:18 PM
cynthy10's Avatar
THE TROUBLE IS IN THE RAIN.I,M NOT TRYING TO HOLESHOT THE CAR BUT IF YOU HAVE TO GET ON IT TO GET IN TRAFIAC ON WET DAYS AND IT BREAKS LOOSE SHE HOPS.
TIRES ARE CHEESEY. NO SPEED RATING ON THEM THAT I CAN FIND LOW BUDGIT BRIDGESTONS THAT CAME ON THE CAR WHEN I GOT IT
I,LL LOOK INTO SHOCKS&STRUTS ANY TIPS ON SOMETHING BETTER THAN STOCK?
BEEN WORKING ON CARS FOR 14 YEARS FOR A LIVING BUT THIS IS MY FIRST PORSCHE THAT I,VE GOT TO PLAY WITH
Old 05-12-2003, 09:22 PM
cynthy10's Avatar
HAD PONY CARS. GOT TIRD OF GETTING BLOWN OFF IN THE CORNERS.
DRAG CARS ARE FUN BUT TACHING OUT AT 70 ON THE FREEWAY BITES!
I'V HEARD THAT THE TRANSAXEL'S ARE WEEK. ARE THE NEWER 944 TURBO TRANSAXELS ANY BETTER? AND WILL ONE FIT WITHOUT MAJOR MOD,S?
Old 05-12-2003, 09:37 PM
1.2gees's Avatar
YES THE 944 TURBO TRANSAXLES ARE IMPROVED, AND ONE WILL BOLT UP TO YOUR CAR FINE, NO MODS NECESSARY. THEY DO RUN A LITTLE PRICY NOWADAYS.
Ahmet
Cheers!
Old 05-12-2003, 10:03 PM
1.2gees's Avatar
AND I KEEP SAYING SHOCKS WON'T CAUSE WHEEL HOP, THEY MIGHT HELP DAMPEN IT, BUT NOT BY MUCH, IT'S BECAUSE OF THE PLAY IN THE REAR SUSPENSION, AND AS I SAID MAINLY IN THE REAR SUSPENSION, STUB AXLES, ETC.
Ahmet
Cheers!
Old 05-12-2003, 10:04 PM
944S Boyeee's Avatar
Send a message via ICQ to 944S Boyeee
Why is everyone yelling???
944S Boyeee
1989 928S4 Canadian Edition
75,000 klms
Old 05-13-2003, 08:04 AM
Ornery Bastard
Sorry, I misunderstood you then. Completely my fault. I need to work on not making a knee-jerk reaction.
Yes, the car is not that great in the rain if it has junky tires. Right now I'm running Bridgestone Potenza RE950's and they are absolutely amazing in the wet. They are very good in the dry too, not the best, but very good and the payoff in wet performance for a car I drive every day is more than worth it. The RE950's even pushed my little car through this past winter in Pittsburgh. Made it through 14+ inches of snow without much drama at all. (Though I topped out at 10 mph in the snow, so I wasn't exactly moving very quickly.)
Aaron
Old 05-13-2003, 10:35 AM
