'86 944T handling woes
When making a sweeping left turns ~70-80mph, the right rear suspension takes intermittant 'dips'; the suspension compresses/drops suddenly then recovers within a half second or so. It wobbles the car back and forth - very unstable. It does not happen on right turns.
I just replaced all the shocks/struts with new Sachs, and had an alignment done. The local shop can't find anything wrong with the right-rear suspension. Any ideas on what might be causing this?
Greg
Old 11-18-2000, 12:31 AM
A Few ideas.
1) You have a bad shock (happens from time to time)
2) The rear ride height of the car is too high.
3) The right rear tire has a slow leak or is defective in some way
4) Right rear wheel bearing is bad
5) The sway bar is disconnected or a bushing is worn.
Old 11-18-2000, 06:14 PM
thanks for the ideas! How can I tell if the ride height is too high? visually, it looks about the same as the left side.
I'll try to check the bearings and sway bar this weekend. thanks!
Old 11-21-2000, 01:45 PM
