In gear no wheel turn
My son (15) and I just picked up a 1986 944. Clutch was on the floor so we replaced by the master and slave cylinders. We have bled them and have pedal. When we put it in gear we are not getting anything from the transaxle to turn the wheels. Could I possibly have a bad clutch or transaxle? The car runs but for some reason the transaxle doesn’t seem to engage. Thanks
Can you see if the rear coupler is turning? #8 here:
Transaxle Removal and Installation Could have a blown clutch rubber center, which you might have seen if you had the starter out, or it could have a blown ring and pinion, or perhaps less likely a CV axle issue. Or maybe something crazy with one of the torque tube couplers if the PO was up to something. -Joel.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
Patrick
Dumb question: Did you verify that the torque tube to transaxle couple get installed? I ask because just a couple weeks ago, I re-installed my transaxle just to see the coupler on the work bench...
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
944 addict
Parking Brake Set?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
I had a 924 that slipped the X-axle to drive shaft coupling during an auto-cross, back in the '90s, it just rolled to a stop and had to be pushed off the course.
It wasn't so funny at the time, but I laugh about it now.
Revis Rose '84 944 NSRC |
![]() Sorry, I fell off my chair reading this because of the times I've done some similar bone headed move. It's nice to know that I'm not alone...
Dan 86 Guards Red 951 (the best so far) 86 Black 951 (sold 12/31/09 PITA) 86 Guards Red 951 (sold in 7/15/00 (first love) 90 Plymouth Voyager, 2.5 Turbo 5 speed |
no need to bother with that collar...when a little duct tape will do the trick!
Kessel run in 12 parsecs!
Why was the clutch on the floor? Do you mean clutch pedal? I think you are referring to the master and slave cylinder issues. Sometime bleeding the system with a fresh fluid change helps.
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
