When you break things....
yes, I did it!! I broke stud on Oil Pressure Sensor.
Felt bad, had to drink my favorite beverage.... http://forums.pelicanparts.com/uploa...1645393937.jpg http://forums.pelicanparts.com/uploa...1645394019.jpg After my favorite beverage kicked in, I did this.... http://forums.pelicanparts.com/uploa...1645394150.JPG http://forums.pelicanparts.com/uploa...1645394150.JPG http://forums.pelicanparts.com/uploa...1645394037.JPG http://forums.pelicanparts.com/uploa...1645394037.JPG http://forums.pelicanparts.com/uploa...1645394037.JPG |
I’ve had the exact same failure but didn’t fix it so neatly. Nice job.
John |
Another opportunity for a unique and satisfying solution.
When life hands you lemons, drink beer?
This shows how important it is to have a right beverage at hand.
Thanks you, guys, again for your "mental" support. |
I admit - I like to break things.
A thin nipple of 3-way vacuum valve on brake booster was broken while I was installing an engine mount. I welded with plastic and it holds well (2 years ago). Now, I finally got a replacement valve. Broken one: http://forums.pelicanparts.com/uploa...1646598282.jpg new, shiny one : http://forums.pelicanparts.com/uploa...1646598338.jpg |
Next time I break a nipple of the expensive cycling valve then I'll send it to you. I couldn't find anything that would hold. It didn't help that the whole thing was brittle with age.
dme - :D
| All times are GMT -8. The time now is 04:24 AM. |
