944 idle
Hey all, 85/2 944 has had a little trouble lately, idle is rough and low at startup (600-800) but smoother after it warms up. Two other problems, possibly related: turning on the a/c at idle causes the same low rough running, alleviated by a little gas, and I occasionally get some deiseling at shutdown. The car used to run hot, but I replaced the radiator, thermostat, sensors and coolant and now it only runs in the upper range on 100 degree+ days, mostly runs cool. Plugs, wires, ignition, rotor and cap are all new. Am I looking at a fuel delivery/throttle problem, or is it possibly just time for an idle adjustment at the shop?
As always, all help is welcomed...
Thanks!
85/2 944 Burgandy (I didn't paint it but I'm sure will someday)
Old 05-20-2003, 10:24 AM
adrian jaye's Avatar
diesling is usually a mixture thing.
have you dont the basics ?
check the plugs/air fileter/rotar arme/distributor cap.
could also have a vaccum leak ?
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 05-20-2003, 11:16 AM
Re: 944 idle
Thanks!
sorry mate didnt read,
re-check the plugs are fine, how about the airfiler ?
is it a s s2 or lux ?
get the mixture checked !
NotJustPorsche
Old 05-20-2003, 11:17 AM
coupe's Avatar
Check idle control valve, vacuum leaks.
coupe
http://www.p-caronline.com/directory/coupe
Porsche 944 Turbo, 1986
Fiat Coupe 20v Turbo, 1997
Old 05-20-2003, 11:24 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
comp. check?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 05-20-2003, 11:57 AM
Thanks for all the info...found a nut missing a screw in the air filter housing, fixed that. Had to have a SMOG check today and it passed, but the problem remains. Guess I'll start running down the vacuum hoses. Also, I noticed the throttle cam is missing a gude, maybe making it too slack.. I'll adjust this and see where it leads me. Thanks again!
Old 05-20-2003, 07:03 PM
