Mein Gott!
How often have you seen this?
It is bound to happen sooner or later. how many 944s have you seen with broken plastic inner fender linings? Very cheaply made. They are connected to the outer fender by two bolts at either end, and one of mine finally gave way the other day, making the outer lip stick out. Is there a way to re-attach this cheaply without having to replace the whole lining? Would a super glue or similar product do the job?
