No voltage to air flow meter
My 1988 924s is not getting any voltage to the air flow meter. Does anybody have any suggestions as to why?
1988 924S 5 Speed |
Assuming it is the same as the 944 then you should be getting 5v from the DME. Either bad output from DME or a broken wire.
Dan 86 Guards Red 951 (the best so far) 86 Black 951 (sold 12/31/09 PITA) 86 Guards Red 951 (sold in 7/15/00 (first love) 90 Plymouth Voyager, 2.5 Turbo 5 speed |
Thanks dme. It is the same as the early 944 and it supposed to get 12v. I get nothing. But the car still runs.
1988 924S 5 Speed |
I can't understand how it can run without measuring the incoming air. You using the test procedure from Clarks?
Never mind. I just discovered my meter wasn't working on volts. I appreciated your input dme.
1988 924S 5 Speed |
That's the best and cheapest outcome possible! Beats having a bad DME, AFM, or wiring.
