944 S2 Sport Exhaust
I am looking to add some sound to my 1991 944 S2. Any suggestions? I am having trouble finding anything. Dansk? Fabspeed?
Old 10-11-2022, 01:21 PM
Toofah King Bad
Rasta Monsta's Avatar
Lindsey?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-12-2022, 10:54 PM
I have a cargraphic on my cab. Not cheap, but very good quality. Unfortunately, not many S2's around to compare the sound to.
Old 10-13-2022, 07:56 AM
J1NX3D's Avatar
Culture, do you have a video with HQ sound? They look like beautiful systems and I'd be keen to hear it. Does it have a 100 cell cat?
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 10-13-2022, 12:51 PM
I tried making a cutout in my Volvo 122S , after doing some work to it.. rebored it 200 CC bgger, hotter cam etc..
bought a 1 inch steel ball and a seat and added a spring behind it. My theory is then it can look and run normal with it's OEM "peashooter" exhaust.
when I had enough backpressure it would open and exhaust out though a little pipe to the road. FUN !
it worked It was quiet as a mouse at idle but open and loud at full throttle. but there was a place where the ball and spring found a state of equilibrium with the spring and then the ball rattled. after a good long run up a 2 hour hill I got the spring hot enough to loose it's tension. i put a bolt in there so I could close it off and I did.
It was also a fire hazard, but a fun project. I thought of maybe using a pneumatic cylinder run off manifold vacuum , or a weight of some sort rather than a spring, and a actual exhaust pipe rather than a pipe pointed down at the road.
a fancy custom exhaust is another idea. probably a better one ;-) it was a fun experiment.
OK, back to your regularly scheduled program ....
Old 10-13-2022, 03:21 PM
currently mine does not have the 100cell cat, but i'm thinking of ordering it.
sorry, but no video or sound clip and currently the motor is out of the car.
Old 10-17-2022, 12:11 PM
Tags
danskman
