Sach or Centerforce clutch?
My cars at 86,000 miles and I can feel the clutch going out. I heard of ceneterofrce and they make pretty good clutches. Never heard of Sach though what woudl you recomend?? Also looking for a lighter flywheel any ideas?
SACHS is the OEM supplier of clutches for Porsche. Recopmmend the spring centered disk rather than the rubber centered one that came stock on the 944.
Performance Products carries an aluminum flywheel for the 944 AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Here is a good thread for reference:
http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=15;t=020982 |
N/A or turbo? I have a lightened steel one for the 951.
It's NA 158hp. I'm looking for a stiffer clutch and lighter flywheel made of Chromoly so it doesn't warp like aluminium.
The factory flywheels typically don't have warpage problems---but still a nice upgrade.
Even though I drove a GT2, I still love my 944. |
Broadfoot has a flywheel for you, just stick w/ the sachs spring centered unit.
The "light pedal force" mechanism designed into the Centerforce clutches are known to fail. Stick with the OEM SACHS clutch.
Does the Centerforce clutches fail in 944 applications? I'm running a CF dual friction clutch in my Mustang and after 4 years of abuse, its still works great! I never installed a clutch in a 944, but my .02 suggestion is sticking with the Sachs clutch just because your running a stock motor and you don't need the extra "grip" from a clutch like CF.
2015 GLK (Momma's ride) 2016 F-250 2001 BMW M5 65 CSX 427 Roadster |
Thanks guys yeah im thinking of just getting the sach oem clutch and resurfacing and maybe dropping soem wight on the oem flywheel. I'm really not sure if my clutch is going out, I jsut got the car and it sure as hell feels light.
Oh, wait a minute. It just feels light? These cars have a very easy clutch pedal, it's hydraulic and doesn't take much pedal effort if properly working. Replace the clutch if you have slop in the driveshaft or if it's slipping.
