Patrick
pfarah's Avatar
1984 fan resistor location
Just in case anyone was wondering...
I've seen many posts regarding resistor locations but I haven't seen a pic of the early models. Anyway, here it is, the puck looking thing connected by two wires right behind the tach. Yep, you have to remove the instrument panel, steering wheel, etc. Not so bad when you've done it a million times...
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 12-23-2012, 12:50 PM
AFM #725
Gawernator's Avatar
Too many needles/leaves on your hood!
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 12-23-2012, 12:56 PM
thekidd's Avatar
Send a message via AIM to thekidd
I have a relay there in that spot, dont remember if the puck was underneath or not Have part number somewhere. Post that # in a bit. And guessing you talking about the front defroster fan resistor?
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 12-23-2012, 01:16 PM
thekidd's Avatar
Heres a thread. The puck is there, but below it i have a relay, and you do not.
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/418795-extra-relay.html
Sorry. Reread that post. Not anything tomdo with your resitor
Old 12-23-2012, 01:28 PM
Patrick
pfarah's Avatar
Thekidd,
The resistor is actually for the driver's side cooling fan. I'm in there for other stuff and just decided to take the pic.
Gawernator,
I clean them off every day. It sucks not having a garage.
Old 12-23-2012, 03:57 PM
AFM #725
Gawernator's Avatar
I usually park in a garage and I STILL have to clean out leaves every day. ????
Old 12-23-2012, 04:56 PM
Patrick
pfarah's Avatar
So, here's the situation...
The resistor reads 1.9 ohms.
The AC fan relay tests fine, the other fan relay is new.
Both fans run on high when the ac is turned on and when the operating temp is getting close to hot.
The driver's side fan does not turn on when the radiator switch is jumper-ed.
Why does the driver's side fan not turn on low? I've already looked into Clark's Garage; maybe I'm missing something and appreciate any insight.
Hope everyone's Christmas was great! I didn't touch the car today at all and feel a little guilty...
Old 12-25-2012, 06:52 PM
Patrick
pfarah's Avatar
I also want to confirm: When the two leads are jumper-ed at the radiator fan temp switch, do both fans kick in on high or does only the driver's side fan run low?
Thanks!!!!!
Old 12-25-2012, 06:56 PM
Kevin.'s Avatar
According to Clark's with the thermo switch jumped, the driver side fan should come on slow speed only.
I have never tried it on my '84 to confirm it first hand though.
Does your driver side fan come on to help cool the car down after a long drive?
I will test my switch for you and let you know for sure this week though. My fans act a little strange sometimes
too. I think the only time the driver side fan comes on slow speed in my '84 is after a nice drive and it helps cool it down while sitting after I take the keys out.
Both fans always come on when the switch gets hot enough to close, and some of my early 944 friends have told me that the driver side fan is suppose to come on "slow speed" first... which never happens.
Old 12-30-2012, 07:42 PM
Kevin.'s Avatar
I have that same damn relay, and asked the same question as well and never got a good answer as to what the hell it is...
Old 12-30-2012, 07:44 PM
smokin_944's Avatar
I agree with Kevin, having had to re-do my cooling system a few years ago. When the thermal switch is jumped, the driver side fan SHOULD turn on at slow speed. The reason there is only one resistor on the series one car is that only the driver side fan has slow and fast speed.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 12-31-2012, 07:06 AM
Patrick
pfarah's Avatar
Both fans come on when reaching high engine operating temp and when the AC is turned on however; I have yet to witness the driver's side fan turn on low at any time. Since the car is under some snow (thankfully under a decent car cover), I must wait until the weather clears up a bit.
Old 12-31-2012, 11:25 AM
smokin_944's Avatar
The driver side fan should start at slow speed on a series 1 car. That is why there is one resistor. On 85.5 cars and later when the fans start (and both of them should) they will be running at slow speed until high temp is reached or you turn on the AC. That is why they have 2 resistors. Check with Clark's garage or RTM.
Old 01-01-2013, 09:29 AM
Patrick
pfarah's Avatar
I understand the circuit however; the fan doesn't kick on when appropriate. I think there may be a wiring issue (corrosion, open) that's causing fan malfunction. It's just too cold and snowy here right now and, unfortunately, I am without a garage...
Old 01-01-2013, 05:47 PM
smokin_944's Avatar
I believe you are correct in your diagnosis pfarah. When you get the opportunity you can follow the process of elimination. In Series 1 cars, the components often suffer from fatigue or they just quit working. I'm sure you are familiar with the usual suspects.
Old 01-03-2013, 09:53 AM
Patrick
pfarah's Avatar
Smokin,
With the extreme cold here, I have no excessive heat issues.
Old 01-03-2013, 10:40 PM
AKCJ's Avatar
This thread has really helped me understand some of the details of the radiator fans/resistors.
I only have high speed on my A/C fan which tells me I need to look at the resistors for that. Does anyone know where they are?
TIA
Red 83 944
Old 01-04-2013, 03:00 PM
Patrick
pfarah's Avatar
AKCJ,
Both fans should turn on high when the AC is turned on and stay on for the duration.
Old 01-04-2013, 07:51 PM
AKCJ's Avatar
Thanks for the reply. I'm actually looking for the location of the resistor(s) that allows the lower speeds on the A/C fan (cabin cooling, not radiator cooling). Does anyone know where to look?
Red 83 944
Old 01-09-2013, 12:50 PM
Patrick
pfarah's Avatar
Oh ok...
Old 01-09-2013, 02:56 PM
