924s sunroof switch wiring
Hi All
I was a bit aggressive in removing my sunroof switch to accommodate my newly rebuilt Blaupunkt Reno radio and I think I might have ripped out a wire from the sunroof switch.
See the image I've attached. I am pretty sure that the black/yellow wire (circled in red) is supposed to be connected to the same connector as the black wire.
Can anyone confirm this?
Currently when I press the switch it makes a noise but the sunroof lifters won't activate.
How do these connectors work? How can I loosen them to insert the wire that I ripped out?
Thank you all for your help.
Old 08-26-2023, 04:48 PM
The black/yellow wire connects to the grey/green wire. I advise a soldered junction.
Old 08-26-2023, 05:17 PM
Old 08-26-2023, 05:26 PM
Brilliant!
I will solder them together and let you know how I make out.
Thank you for taking the time to help me out.
Old 08-27-2023, 08:23 AM
So I soldered the black/yellow to the grey/green.
The sunroof lifters will only retract they will not extend.
Any thoughts?
Old 08-27-2023, 10:40 AM
Sunroof Operation, Troubleshooting, and Repair
Old 08-27-2023, 11:00 AM
So . . .
I had no idea there was a microswitch between the sun visors.
I pressed it and the switch worked fine.
Thank you for your help.
Old 08-27-2023, 11:44 AM
