darnellsgarage
944 rough runnin'!
1986 944 NA runs rough. We replaced the fuel system back to front, checked the injectors, tps, new 02 sensor, cat was not blocked, afm retracked, new gaskets on the intake, new reference senders, no vacuum leaks, and it just runs like ****. Rough at idle and won't make power over 4000.
Any ideas out there? About the only thing I haven't done is rebuild the throttle body, but I can't seem to find the rebuild kits that used to be out there. Arnworx is gone?
Don
don
Old 08-26-2023, 01:46 PM
In the Fires of Hell.....
kdjones2000's Avatar
I don't see anything about ignition/plugs/cap/rotor done. What have you looked at there?
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 08-26-2023, 02:12 PM
darnellsgarage
Yes. I replaced all three.
don
Old 08-28-2023, 03:34 PM
What do the plugs look like after it's rough-idled for a few minutes?
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 08-28-2023, 08:04 PM
Whats your fuel pressure?
Did you replace the DME temp sensor (blue top)?
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP
Old 08-29-2023, 09:46 AM
