-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Engine Harness 2.5/2.6 compatibility (http://forums.pelicanparts.com/showthread.php?t=1145466)
Sjoeyp 08-28-2023 05:13 PM
Will a 2.7 engine harness work on a 2.5 motor from a 1985.5 Base?
Both are manual and it appears that the DME has the same 35-pin connector
Jfrahm 08-28-2023 07:36 PM
I sorta think the 2.7 uses the S2 flywheel and single crank sensor. You could check PET to confirm.
