pearldrum's Avatar
Send a message via AIM to pearldrum
Porsche Crest question, vacuum and fuel pressure...
I was wondering, does there have to be vacuum for the fuel regulator and damper to work? I was just wondering if maybe not having any vacuum is causing me to loose fuel pressure.
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 06-11-2003, 04:54 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
I don't quite understand your questioin, but they are connected at your throttle body. There are two ports on your throttle body. One is for your thermo-vac switch for your charcoal canister purge. it doesn't have very much vacuum, not enough to run your FPR and dampner. The other port has the proper amount of vacuum. Perhaps you got them switched around while you had the head off?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 06-11-2003, 05:51 PM
todwic's Avatar
Then again, that would lead to too much pressure. If you take off the vac. line and hold your finger over the port, it will cause an increase in fuel pressure. If you pull a vacuum on you FPR, it dumps fuel back to the tank.
'86 951
Old 06-11-2003, 05:53 PM
pearldrum's Avatar
yeah, that's what I was thinking. I don't think I can feel any pressure at the regulator. The car has been having problems starting because of loss in fuel pressure for as long as I've had it. We've replaced pretty much everything in the system.
Old 06-11-2003, 06:07 PM
Terry Richards's Avatar
Their is a diagram of the vacume system in the engine compartment on the right front wheel well just above the windshied washer tank.
Terry R.
1988 944 NA AT Alpine White
1987 944 NA AT Stone Grey
1987 944 NA 5 Speed Stone Grey
1987 944 S 5 Speed Triple Black
Old 06-11-2003, 06:13 PM
pearldrum's Avatar
Yeah, my car had a fire before I bought it right there at the coil. I guess the diagram must have burned because there is nothing there. The factory manuals should have one in it.
Old 06-11-2003, 06:23 PM
in here maybe?
http://www.pelicanparts.com/944/944_parts/944_83-85/pic7.jpg
Tom
Early '85 944
Old 06-11-2003, 07:50 PM
Have you replaced the fuel pump check valve? How about the injectors? Both can cause a loss of fuel pressure.
Rob
Old 06-11-2003, 07:57 PM
pearldrum's Avatar
Rob
yep, the fuel rail, regulator and damper...
Old 06-11-2003, 08:53 PM
pearldrum's Avatar
Which port on the throttle body should it be plugged in to?
Old 06-11-2003, 08:56 PM
The vaduum line from the fuel damper and regulator go to the rear most port. The line to the thermo/vacuum switch goest to the frontmost port.
This loss of fuel pressure, does it happen while the engine is running, or does the pressure bleed off while the car is sitting?
If it is the latter, and you have replaced the damper, regulator, and the check valve at the pump, you probably have one or more injectors that are leaking.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 06-14-2003, 07:12 AM
