-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   ATF Lines 88’ 924S (Automatic) (http://forums.pelicanparts.com/showthread.php?t=1151663)
n0va 12-05-2023 10:15 AM
I am in the process of replacing the damper on my 924S and I am having trouble locating where the ATF cooling lines must be disconnected before pulling the torque tube. Any help would be amazing.
rufrob 12-06-2023 03:59 AM
They are difficult to reach if they are the same as the 944. They should run from
The radiator above the exhaust manifold then connect at the top of the bell housing.
