-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   I need HELP guys! (http://forums.pelicanparts.com/showthread.php?t=11523)
Weldin 02-02-2001 08:19 AM
I need HELP guys!
Can someone look at their O2 sensor & tell me were the wire leads to under the hood? PLEASE! It's an early 85....Thanks a million!
Weldin 02-02-2001 01:51 PM
Shaun
Your pic didnt show up -- the reason I need to know is that Im missing the wire that runs between the sensor itself & the wiring harness, and am going to have to splice in something myself -- does it connect to a wire that looks like an ABS connection? Thanks
lm6y 02-02-2001 07:45 PM
Nope Shaun, it's a dead link.
wolfrpi 02-02-2001 10:06 PM
Look on the fire wall next to the dme pick up connections (There should be two sets of male and female connectors coupled together in a metal brace near the rear of the cylinder head and above the flywheel). In close proximity is the O2 sensor hook up. I believe it is cylindrical in shape and black in color.
Erick
Weldin 02-03-2001 05:46 PM
Hey thanks Shaun -- thats what I thought it was....just wanted to make sure....I called a local dealer & they said they cant order just that wire...anyway, so if anyone has one they want to sell???
Weldin 02-06-2001 09:53 AM
Shaun
How do you post pics? I took one because there are 2 empty wires at that location. One is fat & green (1 wire) other has two smaller wires (one male & one female)....is the green wire for an ABS option maybe????
Weldin 02-07-2001 05:01 AM
<img scr=http://albums.photopoint.com/j/View?u=1505934&a=11369557&p=40262028>
Which one is it??
Weldin 02-07-2001 05:02 AM
<img scr = http://albums.photopoint.com/j/View?u=1505934&a=11369557&p=40262028>
Lets try it again
Weldin 02-07-2001 05:03 AM
<img src=http://albums.photopoint.com/j/View?u=1505934&a=11369557&p=40262028>
Weldin 02-07-2001 05:05 AM
Shaun,
Finally got it - which one is it ??
Porsche 951 Fanatic 02-07-2001 10:12 AM
nm... I messed up
[This message has been edited by Porsche 951 Fanatic (edited 02-07-2001).]
todd951 02-07-2001 04:25 PM
Ah, there's a reason why you're not seeing that connector, Shaun. Early cars have a one-wire oxygen sensor, and late cars have a three-wire sensor. If you're looking for a three wire connector in an early car, you won't find one.
Weldin 02-07-2001 05:50 PM
So its the GREEN wire then?
Weldin 02-08-2001 05:21 PM
Hello??
lm6y 02-08-2001 06:21 PM
Yes Weldin, it's the green wire. You will need the connector that plugs onto the one that is empty if you don't have one.
