Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Question (bad ground ? ) gauges needles jumps !
Please help me with this:
My temp gauge some times read wrong lot more, like in cold starting reads 3/4 of temp. (only some times, major of time is correct)
my fuel gauge needle sometimes jumps a little
I already replace the ground strap and battery terminals
let me know your opinion
Old 06-17-2003, 07:28 PM
Roger Hall's Avatar
I had the same problem on my 81 924 I cleaned the connector that attaches to the guage cluster and now the guage reads steady.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 06-17-2003, 07:34 PM
Roger:
Ok I will do it , thanks.
any other idea ?
Old 06-17-2003, 07:42 PM
Clean and tighten the connections to the fuel sender in the back hatch floor. I found these connections corroded and greatly effected the fuel gauge reading and stability.
Old 06-18-2003, 06:30 AM
I will do it
Old 06-18-2003, 09:36 AM
I found an air bubble in mine. Burped the system and the needle stays steady.
1985.5 Eurospec 944
1986 - 944
1997 - Mazda Miata
2002 VW Jetta GLS 1.8T
Old 06-18-2003, 10:33 AM
