Instrument ground wires
Does anybody know where the ground wire block connector is under the dash on a 1988 924S? I've been under there looking for an hour and can't find it.
Old 12-12-2020, 04:00 PM
In the Fires of Hell.....
kdjones2000's Avatar
They are on the underside of the dash on the far left and right of the dashboard.
Follow the brown wires...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 12-12-2020, 08:46 PM
Thanks for the replay. You wouldn't happen to have pictures would you?
Old 12-12-2020, 11:44 PM
Is there anything I have to remove to get to them?
Old 12-13-2020, 09:54 AM
Ernie944's Avatar
Are those the grounds wires your talking about? In the pic there is four of them?
Caraquet,N.B. Canada.
Old 12-13-2020, 10:43 AM
Ernie944's Avatar
[QUOTE=Ernie944;11140713]Are those the grounds wires your talking about? In the pic there is four of them?BTW not sure if this pic is from rigth hand drive car,if so it will be on the opposite side on a US .
Old 12-13-2020, 11:50 AM
Thanks for the pictures. I don't see anything like that under my dash. I think that is where they are on the 944. Mine is a 924S. I think they are different.
Old 12-13-2020, 03:02 PM
Politically Incorrect
onZedge's Avatar
Behind the fuse/relay panel on the foot-well to the left of the clutch pedal. Just pull down the carpet (upper left corner) and you will see a multi-stab male fast-on terminal with a bunch of brown wires plugged in.
Edek
'87 924S
'91 535i
Old 12-13-2020, 08:55 PM
Thank you. I will try that tomorrow
Old 12-13-2020, 10:20 PM
I was wondering the same thing (where are those grounds?) Using the invaluable Search feature I found this thread ... and it helped, so thanks!
John
82 911SC coupe
Old 12-31-2021, 02:33 PM
You are welcome John. I still haven't found them.
Old 01-01-2022, 09:07 AM
Easier if you remove the instrument cluster
82 911SC coupe
Old 01-01-2022, 09:37 AM
universeman's Avatar
Anybody know if it's the same on a 968? Having instrument cluster issues, suspect grounding.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 01-03-2022, 01:30 PM
It is not the same.
Old 01-03-2022, 02:34 PM
Have you found it eventually? I have no clue either where it could be.. 1988 924S too..
Some say it's under the dash above the fuse panel (that no one can find..)
Old 07-21-2024, 10:17 AM
You will have to remove the fuse panel and you will see a star shaped ground connector above the panel in the upper l/h firewall. Hard to see but it is there.
I just cleaned the corrosion on mine, not a fun job.
My suggestion is remove the drivers seat for better access.
Good luck.
1987 924s
Any questions 813-741-3459
Old 07-21-2024, 05:01 PM
No, I still have not found it. I will try removing the fuse block.
1988 924S 5 Speed
Old 07-22-2024, 02:00 PM
if you have access to the end of the wire you know should e grounded you could always just ground it again to some other decent body point If the OEM is bad then it should at least prove it. I dont see an alternate or duplicate ground causing a problem, just thoughtif it helped to not remove the dash or a bunch of stuff then a second wire could be ok from an electrical standpoint. If you are in there sure, clean every ground you can. I don't think you can be too well grounded ;-)
Old 07-22-2024, 02:27 PM
