![]() Oooooooooooooooooooooh. Very very nice.
Early '85 |
> in a no start situation. I know we can all check spark with a spark plug too.
You can check for a spark with a spark plug, but cannot tell if it's strong enough... maybe if it's dark enough and the spark looks a bit too orange you can suspect it's weak. Far better to have a spark checker that can force a good long arc to see if the spark is strong enough. I am thinking couple of spare spark plug wires and a plug with the ground electrode removed, and some stovepipe wire might be handy to set up a gap somewhere where it can be seen when cranking and in enough shade to observe the spark. On an early car that might be easier to rig than a DME relay jumper. If you break down the biggest concern is safely getting out of the traffic flow and maybe then to a place where you can try a DME relay jumper or other fixes or diagnostics. Getting hit on the side of the road is too common. -Joel
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
