Name these gaskets - "headkit"
Head is coming back from the shop next week.
BTW- national cylinder head in tampa fl has been great so far. What are these gaskets that are included in the kit? If I can't figure it out I'll just throw them in cam cover before I seal it up:D http://forums.pelicanparts.com/uploa...it gaskets.jpg |
Oh yeh, the price quoted on the valve replacement at national was $175, I supplied parts
Without a measurement, I will guess the big one is between the throttle body and the intake manifold
#1 between throttle body and manifold
#2 between camshaft housing and front cam bearing cap(must remove) #3 ditto #4 camshaft housing alum. plug washers/seal rings. |
Highboost , You da man......
that would be a pink butane lighter
| All times are GMT -8. The time now is 06:12 AM. |
