Replacement bushing question
Ok... I'm going to replace the A Arm Bushings.
What would be the best choice for everyday use. The polyurethane bushings from Tweeks or the Weltmeister Poly-graphite. They give a note that the poly-graphite will transmit more road noise. Thanks |
Hi...
According to nearly everyone I've talked to and now from personal experience...for everyday use replace the bushings with the stock rubber ones. Much less squeaky road noise, better day to day ride etc...Thanks 1.2, you were right on with that reccomendation. Good, solid, quiet ride again Erik ------------------ Go the distance.... |
