944 A/C Compressor mounting
Help, I have 1986 944. The Alternator - A/C belt started squealing recently so I checked the tension: I found that the A/C compressor mounting bolts are ... MISSING, to my surprise. The front bolt is a M10x1.25 x 50, I thought the back bolt is a M8x1.25x50, but it doesn't fit/screw in. Does anyone know the size of the rear mounting bolt? Can't find in the forum threads....
use a mirror to look and see if its lined up. thats more likely to be your problem why it wont thread.
ok, so the front bolt was threaded, the back not. I found that the back bolt was sheared off. I drilled the broken bolt and used an "easyout" to get the broken bolt out, then I couldn't get it aligned for nothing!! I finally fed a smaller, but close to size nail through to help me get this thing aligned. WOW! it's in, front and back. what a job
And, that was Slick
| All times are GMT -8. The time now is 06:24 AM. |
