Aluminium trailing arm identification
I just picked up two al trailing arms. I just noticed that the hubs that holds the wheel studs are different. One sits right on the trailing arm and the out goes out further. It is 55mm to the backing plate for one and the other is 85mm away. Which one is for which year? I need the 87 and later al trailing arms.
Thank you very much, Alex |
| All times are GMT -8. The time now is 02:09 AM. |
