why make a 5 digit odo?
is that a common porsche thing or what? its like they didnt expect these cars to get past 80k miles. or they just figured it didnt matter since the gear breaks
bah humbug |
Re: why make a 5 digit odo?
yeah, i still need to see what is up with my speedo/odo.. |
It's so every 10-20 years(depending on amount driven), the car will be new, all over again :D
Mine should be new again in a few months ;) |
ALL cars used to have 5 digits. A 100,000 mile car was worn out, and worthless a few decades ago.
Think the 944 went to 6 digits in 84.
Anyone? |
My 84 has the 5 digit. BTW they only had 5 digits because your never supposed to sell your Porsche...:p |
5-digit odometers were common well into the 1980's. They stuck around a bit longer on American cars I think just because there was more of a corporate parts bin.
Aaron |
Your gauges are crooked :p < ----- spent an hour last week making sure his gauges were all lined up perfectly :D |
your speedo is off, it says 90, but the pix is standing still!
is worse now, it says 100, but the pix ix still stationary.
BUT! It also looks like a 911 as there is a hatch something on the left fender. Many want the tach readable behind the steering wheel and rotating it is intentional to get the higher rpms at the top. Could have recessed the instruments a bit further. |
944 with 911 fenders, missouri edition
that fender thing is the cupholder for the guy riding on the hood.
I don't want to seem like an a-hole but wouldn't you want to tilt the speedo more, and the tach less? I mean now the useless range of the tach (past redline)is taking up valuable part of the visible portion of it.
The 911 guys are always abit, tilted... :p Ahmet |
well, the purpose of positioning the tach so the needle points traight up at max rpm is so the driver can "see" redline through his lower periphery without having to take his eyes off the road. He knows that when the needle points straight up, he'd better think about shifting. ;)
why do you need to know when you hit the RED line?
Isn't that what the revlimiter is for? when the revs stop change gears and if you don't have any more gears and you run out revs you shouldn't be looking at any dam gauges. So who real cares. LOL |
I'm not impressed with the pic! I'd like for Kurt V to wait till he got to the curve, THEN take a pic driving with one hand through the turn going 100mph!
wouldn't mind sitting in the driver's seat on that picture though. I can just feel the setup for that left hander. Where is that by the way?
5 digit odo's were common up through mid 1980's
Porsche changed them over on the 944 starting with series 2 (85.5+) 911\930 have always had the 6 digit odos AFJuvat |
OK. Will the 911/930 speedo fit in the early 944's so I can get six digits? Guess I might loose the GPM gauge.
would it matter considering that the mileage won't match anymore anyway?
Nope AFJuvat |
it would if you tried hard enough
or pried, for that matter :D
If the guts are the same then it could be a transplant. |
So, just checking. You'd like to have a working odo again and decided that you want a six digit instead of five? Personally, I'd stick with the original for, well, originality's sake. Unless it's your daily driver, you probably don't want to put too many miles on the car for it to be a concern anyway. Or am I misunderstanding what you want to do?
| All times are GMT -8. The time now is 03:39 PM. |
