944freak's Avatar
Send a message via Yahoo to 944freak
Question Wont start
I have the 86 engine installed in the 83 na. I'm getting spark but no fuel. What should I check. I took the cap off of the fuel rail and cranked her over and no fuel came out.
1983 944
Old 07-27-2003, 07:39 PM
MrPants's Avatar
DME relay is common problem. there is a procedure for checking it, if you search for "DME relay" im sure it will come up. i use the backwoods method of jumping the fuel pump directly from the battery. if you hear it pumping when you do that youll know its workin for sure
84 944 Non Alcoholic
Old 07-27-2003, 11:20 PM
SoCal Driver's Avatar
You can jump the battery to one side of the throttle bypass (idle control) valve. It will run the fuel pump on the early pre 85.5 944's.
If you also run a jumper to the injectors and to the coil you could run the car.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-27-2003, 11:25 PM
944freak's Avatar
thanks for the help guys, I have to relay the info to my dad so he can try these solutions.
1983 944
Old 07-29-2003, 05:18 PM
