Shift linkage question - should this bolt be tight???
In this thread from rennlist:
http://forums.rennlist.com/rennforums/showthread.php?threadid=48566&highlight=shift+link age Should the bolt that is safety wired, that holds the shift linkage to the shaft from the transmission be tight??? I have quite a bit of play in my shifter (I have the Autothority short shifter as well) and I checked the linkage today and that bolt was a few turns loose! (no safety wire either!). Should it be tight, or not?? Thanks, |
As I recall I made sure it was snug and blue loctite on top of that..........and the airplane wire.
Safety wire. Used in many places aircraft just being one of them.
| All times are GMT -8. The time now is 06:30 PM. |
