87 944 NA, orings and swaysbars?
Hi Guys,
1987 944 NA, couple quick questions. What size are the o rings that are in the (2) hose to AC compressor. They are two different sizes. Also I want to install a rear sway bar on this car, it didn't have one from the factory. Do I need the kit Pelican sells? Thanks, JB Bergman |
I don't know about the A/C stuff
As far as the rear sway bar, you will need the drop links that mount to the rear swing arms and then to the sway bar. Ther are also two "U" shaped brackets that keeps the sway bar mounted to the body. Your car has all the spots needed to mount but probably needs the items as stated. If you are buying a used swaybar, many guys include these parts but you may need to ask Here's a photo of the U bracket (there are two needed), I don't have any photos of the drop links which mount to the ends of the swaybar. You will also need the bushing that goes in this bracket. Picture of the "U" shaped bracket on sway bar
AC & sways
I've got all the parts off of an 88. I didn't know if I needed anything else. The ecsentric bolt holes in the rear arm seemed different some how.
JB |
AC O-Rings
Anyone know the sizes?
