cylinder head repair
OK all you 944 owners, has any of you actually taken the head off your car. I read in the haynes manual about special tools for tensioning both the balance shaft and cam belts. Also they talk about contacting the dealer for head bolt torque specs. What are the secrets to these issues. Any help would be much appreciated.
Steve MA 83 944 red tan int
Old 08-25-2003, 04:57 PM
Scott R's Avatar
Anyone who is a member of the "bent valve club" has removed a 944 head, or had it done somewhere. I pulled mine to swap in a better head gasket. It's not terribly difficult and the torque procedure is listed at "Clark's Garage."
As for tensioning the the belts special tools are necessary to perform the job correctly. The 9201 belt tension meter, the flywheel lock, and the balance roller spanner wrench. The spanner and flywheel lock can be had for a few bucks on Ebay, The 9201 will set you back several hundred. Best to borrow the tool if possible, there are three in my local PCA zone, including mine so we just let other members use them. Some shops loan them out as well.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-25-2003, 05:52 PM
Thanks Scott, very helpful I will look for the tools around the local area and on ebay
Old 08-25-2003, 06:53 PM
SoCal Driver's Avatar
I set my timing belt to a C sharp.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-25-2003, 07:02 PM
Scott R's Avatar
So the infamous "belt whine" should be a solid "C sharp" and then the tension will be dead on?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-25-2003, 07:17 PM
