924s Dme
I bought an Autothority Chip and a K&N Cone Filter.
However, I am having trouble finding the DME on my 87 924S, does anyone know where to locate it? Also, the Filter came without instructions, how does one install it?
Old 08-14-2003, 09:01 PM
MrPants's Avatar
you will have to remove the airbox to install the cone filter. there are 2 bolts at the front and 2 at the rear that attach it to the air box frame thing. i think thats all.
there should be a hose clamp or some sort of adapter that came with the cone filter to attach it to the intake hose.
84 944 Non Alcoholic
Old 08-14-2003, 09:08 PM
SoCal Driver's Avatar
Where is the DME?
Look under the dash. It's attached to the bottom of the steering column.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-14-2003, 09:37 PM
Any tips on gettint it out?
Old 08-16-2003, 07:31 PM
vott does ziss do?
ronin's Avatar
it should just slide off the plug
Old 08-16-2003, 09:58 PM
And take the bolts out.
10mm heads.
Turn couter clock wise.
Lefty Loosie, Righty Tighty!
Old 08-17-2003, 08:50 AM
Should I remove the entire DME or can I open the case and swap the chip with it connected to the car?
Old 08-17-2003, 09:17 AM
If you like laying on your back with the steering wheel poking in your ribs just do it in the car.
I would take the unit out.
Old 08-17-2003, 09:58 AM
