throttle switch & oil
I removed the throttle switch from under the throttle body and noticed that the switch itself was full of black oil. Is it supposed to have oil in it? Thanks,
Old 08-26-2003, 06:06 AM
Roger Hall's Avatar
I can only relay what I have read in previous posts. I have never taken apart the TPS on a 944. I have read that it is common for the TPS to fill will crud becase of how it is mounted. It doesn't seem like there should be any oil in there.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 08-26-2003, 05:50 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
It's electric, not hydraulic. No oil should be in there. Clean it. adjust it. It should click just as soon as you crack the throttle.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 08-26-2003, 05:52 PM
A couple of weeks ago we had an '84 944 with a sticking throttle.
The tech took the throttle body off and found that the throttle shaft was sticking due to the amount of "unidentified crap" in the throttle body bushes. Once cleaned off it was like new. Maybe someone had cleaned the throttle body in your car and this was the residue from the carbon and solvent? Clean everything off, adjust the TPS and make sure the idle is ok.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-26-2003, 09:31 PM
