has anyone else had the problem of the small nipple at the top of the radiator on the drivers side breaking off? if so any common fixes? for now i siliconed the crap out of it.
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
Writer/Teacher
i don't know, but nipples supposedly grow back when they break off...
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Yes. That fitting is prone to crack where the fitting meets the wrench flats. I have broken two of these fittings just trying to replace the hose.
If memory serves this part is about $11.00 from a dealer. Get a new fiber washer as well.
Cliff Hipsher '87 944 India Red '86 951 Kalahari Metallic |
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
What would Darth Vader do
Silicone will only work for a short time. You will need to replace it with a new piece
1983 944 (2002 to now) 3-924's (Sold) 1967-912 (Traded) NEVER put a used water pump in your car... |
