Send a message via AIM to lilwolffeman
turn signals get stuck
my problem is that when i turn on the turn signals, after a few flashes the light in the instrument cluster just stays on. if anyone has had the same problem could you tell me how to fix it, thank you.
85.5 944 NA
Old 09-07-2003, 11:22 PM
vott does ziss do?
ronin's Avatar
probably the flasher relay needs replacing. might be malfunctioning as it heats up. just a thought. check outside to make sure the same is happening with the turn signal indicators and that it's not just a problem in the instrument cluster.
Old 09-07-2003, 11:29 PM
the light stops flashing, it just looks like my lights are on and i don't have my blinkers on. also most of the time when i start my car, the tach is stuck at 0. i just tap at the cluster a couple of times before it goes up.
85.5 944 NA
Old 09-09-2003, 04:51 AM
afx afx is offline
afx's Avatar
Send a message via ICQ to afx
I would say to just try out a new flasher relay. They are pretty cheap (around 6 dollars).
85.5 Red 944
Http://members.rennlist.com/afx
Old 09-09-2003, 07:42 AM
SoCal Driver's Avatar
Found the problem: "i just tap at the cluster a couple of times..."
Remove and clean-tighten the instrument connections.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-09-2003, 08:52 AM
Pike's Avatar
Location: Redmond WA Can anyone help me with my snorkle mod?
Check and see what happens when you turn on the hazards. If all of the blinkers are running, the problem is most likely the relay. If they are not, check the bulbs and the sockets.
'77 924 - Metallic Blue - enlarged TB/ intake
'99 Specialized HardRock - Blue/Silver - Jett C Shocks - Cat Eye Velo computer
If it ain't broken, drive it until something is.
Have you spent quality time with your Engine Gnome lately?
Defend Your Joy
Old 09-09-2003, 09:52 PM
