-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   bold patterns and offsets (http://forums.pelicanparts.com/showthread.php?t=126737)
dj_yen 09-09-2003 06:22 PM
oh gurus of the board hosted by the fine purveyor of parts from pelican!!!
please, bestow thy knowledge upon me!!!
what is the bolt pattern and offsets for 15" phonedials on an 87 944 and 944S?
i sacrifice my first born for thine grace and wisdom!!
dj_yen 09-10-2003 07:59 AM
bump
Dantilla 09-10-2003 08:47 AM
All Porsches use the same bolt pattern, which is used by nobody else.
You have either early or late offset wheels, which are also the same between 911s and 944s. Your car has anti-lock brakes, so it has late offset wheels. Early offset wheels will stick out your fenders. Late wheels can be used on early cars with spacers.
That's about all I've got to say about that.
dj_yen 09-10-2003 10:37 AM
thanks for the info dantilla, but i still don't know what bolt-pattern it is.
i have seached the forums and i believe the offsets are 56mm for a late model 944 but i still cannot find info on the bolt pattern
no one knows?
i find that hard to believe here at pelican
dj_yen 09-12-2003 07:53 AM
bump
DA_MUTT 09-12-2003 10:27 AM
5 x 130
dj_yen 09-12-2003 10:36 AM
thanks!
btw, Mutt, do you have a catalog or website so i may review the dash accessories you carry?
DA_MUTT 09-12-2003 10:39 AM
Sure, if you want to shoot me an email with the info on your car at:
mildwild@rochester.rr.com
I will send you the info and color samples on the kits.
~Lisa
