CSU944's Avatar
Altitude switch?
I'm up here in Colorado, and was wondering about the altitude switch. What does it do, do I really need one, and where can I get one if I need one? Or, can I just jump out the terminals?
-Thanks!
Old 09-12-2003, 08:59 PM
Yes, you need the switch.
The switch is set to operate at altitudes above about 4500 feet (if memory serves).
The purpose of the switch is to tell the DME that the fuel mixture needs to be adjusted for high altitude.
With out the switch the engine will run, but since the fuel mixture is "off" you may not be able to pass emissions testing.
Any decent dismantaler like 944 Ecology or Parts Heaven shoul be able to hook you up.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 09-13-2003, 09:05 AM
will944's Avatar
Send a message via AIM to will944
Is an altitude switch needed in a post 85 1/2 944?? I was always under the impression that they were only on the early 44s?
PS........GO BUFFS!!!!!
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 09-13-2003, 10:42 AM
EVERY car needs some form of high altitude compensation.
Cliff Hipsher
'87 944 India Red
Old 09-14-2003, 09:10 AM
