anyone know any really good way to loosen a stuck oil pan bolt? i tried putting my wrench on the end and bashing the end of the handle but that didnt work... right now it is soaking in the wd40 i put on it.
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
Hit it with a hammer. Use a steel rod to get to it if necessary. A couple of direct whacks tends to break the treads loose. If they are destin to come loose.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
yup yup tried that.... now what?
nuts and bolts
use a nice tight fitting 6 point socket, use shortest combination of extensions, long handle ratchet or breaker bar, straight 90 degree approach with the wrench, and push it farther onto the head as you give it a quick, hard, fast unscrewing turn.( no offense, be sure you are going the unscrew way, counterclockwise) if you still cannot loosen it, whack it while the socket and extension are on it, no wimpy whacks allowed, very firm. if you do end up using heat, have wet rags around it and an extinguisher. you could refill with oil, and take it to a shop, they do this job everyday, and if it breaks, that is where you want the car when it breaks. great luck!! in my mind, its already loose!!
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
yeah i gave up on it. bashed the crap out of it a bunch of times, then i just got under it braced myself and pulled as hard as i could but the bold won and the socket lost... snapped a wall of it off.
ill just take it somewhere this time.
Lefty Loosie -- Righty Tighty!!!
yes, but now you get to buy a new socket!!!!!! or trade in if its sears/snappyon
Let's go shooting.
What you need is an impact driver - basically a spring loaded 1/2 inch socket drive. You'll find them in any bike shop that sells Japanese machines - they're essential for loosening cross-head steel screws in aluminium casings. They have a mutihead attachment that takes a variety of screw types / sizes. This can be removed allowing you to use a carbon steel socket (black coloured as used on airline wrenches in tyre shops).
Set the tool to it's anticlockwise setting and give it a damn good thump with a wooden or neoprene mallet. If that doesn't get it off I'd be bloody surprised.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." |
or i could just take it to a shop and hand them MY filter and MY oil and tell them to change it using that...
Let's go shooting.
Chuck in the towel, you mean? Yes there's always that option - and for many it's probably for the best.
Are you removing the drain plug? or an oil pan bolt??
Drain plug - get a longer wrench - longer the better - try applying heat, followed by PB blaster. (do NOT impact unless you have no other option - you can pull the threads on the oil pan) oil pan bolt - Heat, bigger wrench, PB blaster, impact as a last resort Torque to no more than 50NM (33ftlbs) when you put it back on - use a new crush washer, a little anti-sieze on the threads works wonders. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
drain plug..... stupid thing...
Yeah! What AFJuvat says. Don't hit the drain pug.
Note: This is NOT a bolt.
