Option code 456
Just purchased an '86 coupe and was wondering if someone could describe what's meant by 'Sport Shocks and stabilizer' as referrenced by the option code 456?
thanks. |
koni yellow shock and sway bars all around, that is awesome i have had them on both of my cars and they are just amazing, so much nicer than the original boge shocks, you don't know how lucky you are to have that. Great for autox!, good work on geting a 944 thats awesome
'84 944na -- Sold '84 944na -- Sold '85 944na, -- Sold |
Aren't they adjustable shocks?
I have this option as well, but my fronts are coil overs (obviously not stock), the rears are koni yellows, but a little soft in really hairy stuff, can't I unbolt them, and tighten them up?
Brad Tompkins Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968 |
Koni Yellows / Sport Suspension is option code 474.
Not sure what 456 is: the sources I have do not have that listed. Do you have yellow colored shocks on your car? -Zoltan.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
err, your right, I have 474, dunno 456 :P
http://www.cantonia.com/option_codes.html
http://www.geocities.com/MotorCity/3322/spec.htm Both of these list the Option code 456 as Sport Shock Absorbers and Stabilizers and Option code 474 as only Sport Shock Absorbers. I guess the only way to be sure is to get a wheel off and get in there for a proper look? |
89 951 |
