-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Air Conditioning Fuse Problems (http://forums.pelicanparts.com/showthread.php?t=13252)
nitrousdrip 07-02-2001 09:05 PM
I have a '87 944S and whenever i turn my air conditioning on, the fuse will blow. The air is on the same fuse as the heat, but when i turn on the heat, the fuse wont blow. I'm stuck!?!
Are there any common electrical problems i should check for?
Any suggestions are greatly appreciated.
thanks
Lawrence Coppari 07-03-2001 04:01 AM
I had a similar problem. Stan Kolen advised cleaning all the contacts to include the fuses, relay (inside and out), plus battery terminals and grounds. This fixed my problem. My fuse would not blow immediately but would go after about an hour.
I would see what I considered to be an abnormal drop in volt meter when AC was switched on. You might have a dead short somewhere from the way it sounds (because your fuse blows immediately).
My understanding is that there is a capacitor associated with the compressor clutch. If it is shorted out, the fuse would blow. A wrench told me this.
[This message has been edited by Lawrence Coppari (edited 07-03-2001).]
Rob-O 07-03-2001 04:23 PM
Nitrous,
I had something similar happen to me. There is a weird switch on the power steering pump. Supposedly it senses the rpm's and raises it when you turn the heat/ac on. I think this switch is only on the "S" models. Pull the little boot on the p/s pump and take a look at the switch, this may be your problem. It was immediately evident that mine was toasted.
Rob-O
nitrousdrip 07-03-2001 04:30 PM
Thanks a lot guys, i'm gonna go check it out now, i'll tell you how it turns out
Ben
mhariush 04-25-2012 07:05 PM
hi nitrousdrip,
did you ever figure this out? I have an 87S that does the same thing.
