Obin Robinson's Avatar
Talking 924 port/polish is DONE!
http://209.4.91.164/cylinder_head/done/
ok, if i cut any more out of the head it will start being detrimental.
i took the head outside and hosed to completely down with a high pressure hose nozzle. then i let it dry in the sun (don't want lint on it). i then took the head around to the side of the house where there was some sunlight and i snapped a few photos while it was drying.
what do you guys think?
i am going to double-check all my measurements and then the reassembly will begin (hopefully) this weekend.
also, should i get the head dipped in a hot tank or should i just keep it hosed down and degreased? i let it air dry in the sun. i didn't even want to dry it inside and let dust settle on it.
thanks!
obin
Wej doen niet mee an de moduh
Old 07-03-2001, 06:30 AM
Post
Port/polish looks great, you'll have a busy weekend. Hay obin, I wonder if you could check something for me. I just did a valve job and finished reassembly. I can't think of what it's called but there are four single wires that connect just under the throttle body housing. Can you check the order, I took pic's during disassemble but the color didn't show up to well. Thanks
DRIVE IT, BRAKE IT , AND REBUILD IT BETTER !
Old 07-03-2001, 07:32 AM
Cool
4 electrical wires under the throttle body. hmmm, let me see the picture, the colour doesn't matter.
thanks!
obin
Old 07-03-2001, 08:04 AM
Post
throttle switches?
Old 07-04-2001, 08:49 AM
Post
Can you see what order there in, looks two hook ups. I don't know what order, right now it's from right to left looking from the passenger side brown then white and the next one is brown then white with a stripe.
Old 07-05-2001, 06:13 AM
