http://209.4.91.164/cylinder_head/done/
ok, if i cut any more out of the head it will start being detrimental. i took the head outside and hosed to completely down with a high pressure hose nozzle. then i let it dry in the sun (don't want lint on it). i then took the head around to the side of the house where there was some sunlight and i snapped a few photos while it was drying. what do you guys think? i am going to double-check all my measurements and then the reassembly will begin (hopefully) this weekend. also, should i get the head dipped in a hot tank or should i just keep it hosed down and degreased? i let it air dry in the sun. i didn't even want to dry it inside and let dust settle on it. thanks! obin ------------------ Wej doen niet mee an de moduh |
Port/polish looks great, you'll have a busy weekend. Hay obin, I wonder if you could check something for me. I just did a valve job and finished reassembly. I can't think of what it's called but there are four single wires that connect just under the throttle body housing. Can you check the order, I took pic's during disassemble but the color didn't show up to well. Thanks
------------------ DRIVE IT, BRAKE IT , AND REBUILD IT BETTER ! |
thanks! obin |
Can you see what order there in, looks two hook ups. I don't know what order, right now it's from right to left looking from the passenger side brown then white and the next one is brown then white with a stripe.
