-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   blinker fuse keeps blowing (http://forums.pelicanparts.com/showthread.php?t=132710)
ds475 10-22-2003 05:54 PM
my blinker fuse blew 3 times yesterday, i'm about to just short it with some wire. why would it all of a sudden start eating fuses one day. i have never blown a fuse before.
Scott R 10-22-2003 06:01 PM
I had this happen to me as well, and in one large repair I cleaned all of the buld sockets with steel wool, and the negative battery grounds, and also the turn signal switch contacts.
Problem went away, but I don't know which phase of the repair arrested the problem.
Macfreak007 10-22-2003 06:28 PM
my problem went away after cleaning the grounds in the hatch area, I think it started after i go those a little bit wet vback there, when i was cleaning, give it a try, hopefully it fixes it, its a pain i know!
pearldrum 10-22-2003 06:52 PM
Speaking of grounds, alot of the problems that arise in these cars come from grounds. I would go ahead and clean all of them you can get to. There's a big one on the back of the engine, one next to and below the coolant tank on the frame, one by the headlight motor on the frame and a few other small random ones bolted in odd places. These are the main ones though.
ds475 10-22-2003 10:12 PM
why would a bad ground cause a fuse to blow? it seems like it would be the other way around...
ds475 10-22-2003 10:18 PM
i just thought of an idea, too. after steel wooling/sanding my ground, i'm going to get some silicone and try to seal the ground connection off from moisture. seems like a pretty good idea to me.
ds475 10-22-2003 10:43 PM
Wilk, i don't get your comment with the quote...
ds475 10-23-2003 08:09 AM
is the reason that when your grounds "go bad" you blow fuses, because there is more resistance, and therefore draws more current, and since the fuses/electronics are in series with the ground (no *****), it then blows your fuse(s)?
adrian jaye 10-23-2003 08:27 AM
ds,
dont, dont dont, hear me now DONT
short the fuse, its dangerous and if anything happens you'll invalidate your insurance.
fix the problem, as, has been suggested
laters
Cebu 10-23-2003 09:08 AM
Use bearing grease or vaseline on ground connections and battery connections (after cleaning) and prevent corrosion and contact problems. On systems with dual contact bulbs, When the turn signal is activated, (it has wiper contacts inside the mechanism)if the ground is bad, the system seeks a ground and it is reverse current through the bulb contacts that causes the fuse to blow or the bulb to explode.
ds475 10-23-2003 05:15 PM
well... it's not like i have comprehensive anyway...
ds475 11-17-2003 10:43 AM
Macfreak007, your idea worked! after i finally got around to cleaning the ground on the very back, and all of the corrosion off of the bulbs in my rear lights (and front blinkers) it stopped eating fuses! thanks!
P.S. in your post you stated that you cleaned all of the grounds in the hatch... i only know of one, and thats the one in the very back.
Dark Skies 11-17-2003 11:10 AM
You should use liquid rubber / Sikaflex or similar - don't use the type used for sealing plumbing / baths etc - it's usually got acetic acid in it and corrodes your wires / metal.
Better - put a dollop of coppaslip on it.
Macfreak007 11-17-2003 03:45 PM
haha, awesome, yeah its amazing sometimes the things you never thought would help really do. Something as simple as grounds. Glad to hear it fixed the problem. That main ground is the only one i remember in the back i was wrong. But glad it worked
