how to clean fuel strainer?
i took the fuel strainer out of the bottom of my gas tank, and the fuel is like syrup coated onto it. No wonder the past 2 fuel pumps burned up, it was probably from lack of gas!!! What would be a good solution to clean that thing with? would carb cleaner do it?
1986 944 non-turbo
Old 10-30-2003, 03:57 PM
Feelin' Solexy
Tishabet's Avatar
Try some gas and an old toothbrush.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 10-30-2003, 04:38 PM
gas won't eat it off, because the strainer is clogged with a syrup like form of gas!!
1986 944 non-turbo
Old 10-30-2003, 07:06 PM
Feelin' Solexy
Tishabet's Avatar
Trust me on this one, I've freed up tank senders from cars that have had the same gas in their tank for 70 years using a toothbrush and gas. If you want some more ooomph, feel free to pay $30/gallon for carb cleaner. And that syrupy gas is generally referred to as shellac. If you have it in your tank components, you should really clean and reseal the tank with a good pro quality sealant, like the ones marketed by POR.
Grant
Old 10-30-2003, 07:27 PM
SoCal Driver's Avatar
Sounds like some one sugar cube'd the gas tank. Try boiling water.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-30-2003, 07:46 PM
