-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Key button (http://forums.pelicanparts.com/showthread.php?t=136785)
Rock 11-21-2003 08:18 PM
Key button
There is a button on the little thingy above the shift knob... you know where like the sunroof button and the back windshield button is. Ok but this button has a little Key on it, and you can push it down and stuff. Does anybody know what this is?
I'll get a pic tomorrow... but maybe somebody might know without a pic
will944 11-21-2003 08:55 PM
Power Lock Switch
Rock 11-22-2003 01:28 PM
its powered doors... it dosent work for some reason
TheCooler 11-22-2003 01:52 PM
Check the fuse.
Rock 11-22-2003 01:53 PM
checked it, its fine
will944 11-22-2003 05:10 PM
Take the door panels off. When pressing the lock button you will see the power lock mechanism move in and out (rubber boot with a 4-5 inch white plastic rod connected)
Make sure that the white piece of plastic from the power lock mechanism is connected to the door lock shaft (vertical metal piece coming directly from the handle). There is a small knob on the door lock shaft that the white plastic piece connects to.
Press it on and the power locks should work.
ronin 11-22-2003 10:45 PM
....and the red light should come on
Rock 11-22-2003 11:30 PM
the red light on it does come on, its always on, except when i push the thing nothing happens
ronin 11-24-2003 01:50 AM
ahaa, perhaps faulty switch. replace with a good one to see what happens. these switches can sometimes be "fixed" by opening them up, cleaning the contacts and making sure all parts are intact and not broken
will944 11-24-2003 10:38 AM
Yeah...check the switch first.
Then check and see if the power lock mechanism is even hooked to the door handle like I said. If it's not those two...I have no idea
ae1969 11-24-2003 10:52 AM
....Check the switch on the dash but once you have wasted all your time looking for the cause it will more than likely be a faulty microswitch at the doors................ I HATE THIS POWER DOOR SYSTEM.
