Horn gone wild
sometimes, when i start my car, my horn just starts honking, with always a new different rhythm to it whenever it does this. it doesn't do this everytime i start the car, but happens, maybe once a week, if that. it's rather annoying, and when i'm leaving a friends house at say... 2 in the morning and my horn goes buck wild, i'm sure his parents don't appreciate that... anyone experienced this before? any ideas?
'82 928S ![]() '85.0 944 Not Awesome - Being Parted Out
Factory alarm.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
least common denominator
So your horn gets drunk at parties and flashes cameramen?
Sorry... had to get it in there before someone else...
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
just disconnect your horn as it isnt important anyway?
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
I put a Momo steering wheel on my S and everytime I would turn a slight corner, the horn would beep. It got rather annoying. So one day after school when it was on a frenzy, I took the relay out, umplugged the wires in the steering wheel and took the fuse out.
Samm--It's short for Samantha... Keystone Heights, Florida Florida Crown Region--PCA 2006 Acura RSX 1984 944 Track Car 1972 914/6 Race Car |
could have just saved your self all that trouble, and taken the fuse out?
Yea well I always have to do thing the hard way.
i like my horn! i wouldn't mind installing a more commanding horn.
anyone know how to fix this probleM?
I think it's your alarm. I'd fix this before imobilizer decides it does't like you and leaves you stranded.
Disconnect battery. pull rubber vent cap from driver's B pillar. Now you can get to alarm key switch. It has 2 wires going to it. If you want to remove it, there is a 18 or 21mm nut on outside under beauty ring. Check wires and lugs for corrosion. I believe alarm module itself is on tunnel in very front of console, you could check it for loose connections. Beyond that, $75 to dealer for new switch. If you don't have alarm, beats me good luck
'84 944 auto stock |
i don't think i have an alarm. the horn doesn't honk like an alarm going off, either. i don't have an extra keyhole on the handle, either.
Identify any other electrical component that operates with the same rythm as your horn is beeping, you probably have an earth fault which is intermittent. Does it make any difference how long the car has been standing?
(x)'89 944 S2 Cabriolet (Guards Orange) : ( )'90 944 S2 (Maraschino Dead!) : ( )'89 Audi 90 Quattro 2.3 20V : ( )'92 Renault Clio 1.4 : * |
no, the car can be shut off, then started up, and it may do it.
