-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   A/C system charging valve location? (http://forums.pelicanparts.com/showthread.php?t=13813)
Pinseekers 07-12-2001 08:51 PM
Can't seem to find both (high & low) valves.
There is one right on top, above looking glass (obvious location) but where is the other valve???
thanks
Rob-O 07-12-2001 09:03 PM
Bottom of the car. On the compressor...you'll see 'em.
scottewid 07-13-2001 06:29 AM
Seems to depend on what year your car is. From what I understand, the early models have the low side test port(for charging and pressure testing) right on the compressor, and the high side test port (for testing pressure ONLY) on the line running on top of the engine next to the driver's side fender.
On my 1986 951, both the low and high side ports are right on top in plain view on their respective lines running next to the driver's side fender. The low side, where you charge, is the fatter of the two lines and will get cold when the system is running. The high side is the thinner line and gets hot when running. NEVER hook a charge can to the high side because you risk exploding it from the pressure.
White951 07-13-2001 06:43 AM
Hey guys,
I have been interested in trying to find out how to maintain my air conditioning system on my 86 951. I work on the car myself, but don't know anything about the AC. How and where can I find out how to check it out and recharge?
John
mike944 07-13-2001 07:11 AM
White951 -
there's really not alot you can do on your AC yourself, unless you can get your hands on some R12. I believe you can't buy it legaly in the US anymore. I know it hasn't been legaly manufactured in a few years. you can get some black market stuff made overseas, but i've heard it's junk. you might be able to find some at a swap meet, or something, but be prepared to pay for it. other than that, you'll need a gauge set, and charging hoses to do any recharging.
To just check the freon level, find the dryer, which is about a 2.5" dia x 10" metal can in the AC system. there is a glass window (you'll probably have to clean it.) when the AC compressor is running, you should see nothing in the window. If you see any bubbles, that means it's low on freon.
there really isn't any maintenence to do on an AC system. Almost everything involves discharging it, opening it up and recharging it.
Mike
scottewid 07-13-2001 07:17 AM
John, go to www.aircondition.com and www.autofrost.com. They both have great tech articles on how auto a/c works and how to fix it. You should also go to www.epatest.com and take the easy online test for $19.99. This will give you your epa certification 609 that allows you to buy r12 and other refrigerants, also available online from www.refrigerantsales.com.
A/C is really very easy to understand and work on. Once you get your 609 cert and are ready to start working on your a/c it's critical that you get gauges. You simply can't do any meaningful work on a/c without gauges because then you're taking a total shot in the dark and might end up breaking it rather than fixing it. One of the biggest mistakes peoply make is adding refrigerant willy-nilly, thinking that any a/c problem is due to low freon. Most times they end up overcharging which will make your a/c blow warmer, along with other nasty things. You can get new gagues and other a/c parts at www.acsource.com, as well as quality used ones at www.firstcash.com.
If you get really serious about a/c work, then you should also get a vacuum pump and one or two NEW barbeque grill propane tanks. You'll need the tanks to recover refrigerant from any system that has a charge in it before you open it up. You can get the fittings and hoses to hook up the tanks at any hardware store.
scottewid 07-13-2001 07:27 AM
Whoops, try this www.acsource.com the first one had a comma in it.
Also, you can still definitely get R12! True, it hasn't been manufactured since 1995 in the US, but there's plenty still available for sale from existing stocks and refrigerant recylcled from old discarded systems. Auto salvagers and a/c shops that convert cars to 134a are required to drain the old r12 out of systems and send it to recyclers where it gets cleaned up and dried out, repackaged and resold. I buy my r12 from www.refrigerantsales.com and Pep Boys. Pep Boys is more expensive, $45/12oz can versus $40/12oz can online, but sometimes more convenient. When I go to Pep Boys, I just see the manager, show my epa 609 cert card and they get the cans out of a locked cage in the managers office.
White951 07-13-2001 07:38 AM
scottewid,
Thanks for the info. I will definitely check it out. I now r12 is still available, you just pay for it big time. From what I understand from looking online at various sites, I don't even know if the compressor is engaging. I don't think it does because I don't feel anything happen when I turn it on. I have read it may be electrical wiring causing the clutch to not engage or low freon. Off we go into the AC world. Thanks again.
John
White951 07-13-2001 08:10 AM
Scottewid,
I looked at the sites you posted. Is there somewhere in these sites that say "here is what should happen. If it doesn't do this, then this,etc."
John
Pinseekers 07-13-2001 09:05 AM
so how do I charge the system with one valve on top and the other on the underside?
I have an 86 NA. I purchased the kit from Walmart for $35 that converts the system to 134 from r12.
Should I just pay the $208 the pro's want to charge for retro fitting my system?
scottewid 07-13-2001 10:57 AM
Pine, seem my post under "More AC Stuff. Yay". It explains what's involved in a 134a retrofit. I think paying the rather modest $200-$300 for a professional to do it right is worth it. Some folks have been successful with the DIY Kmart kit, but I can't imagine how. Read, the post, you'll understand what I mean.
Also, why do you want to retrofit? If your a/c is working fine now, why not keep it r12. If it's leaking big time, like needign a charge every couple months, then I can understand. 134a will be a lot cheaper to charge up that frequently (assuming you don't fix the leaks) But if it's not leaking, leaking real slowly, or you plan to fix all the leaks, I'd stay with r12.
John, those sites will give you a good overview of a/c and refrigerant theory, kinda a/c 101. When you say you looking for something that will give you steps to follow, do you mean like troubleshooting? If you want troubleshooting advice, go to www.aircondition.com bulletin board. It's the one that says "questions" on the upper right of the home page. Those folks will give you great advice. I may also be able to help if you have a specific question. Scott R and Lawrence C. also are pretty knowledgable about a/c stuff. Between us and others here, we should be able to help.
Pinseekers 07-13-2001 11:23 AM
Thanks Scott. I had already posted the previous message before I read through Andre's post about MORE A/C.
I think in this case I am going to shell out some cash and let the pro's do the job!
Lawrence Coppari 07-13-2001 03:25 PM
Five years ago the AC began leaking on my 21 year old MB Roadster (was only 16 then). I use a substitute regrigerant that is mostly propane. Certainty I was concerned about the refrigerant eating the system but 5 years is 5 years. Well, I let it go for a year because MB parts don't cost as much as P parts. It's been in my 944 for 4 years with no harmful effects. Blow up the car in a wreck - I don't think so. It is distributed and only 60% of the amount of Freon.
White951 07-23-2001 06:39 AM
Scottewid,
My car also is a 1986 951. I looked under the car this weekend to see if the compressor clutch would engage, it did not. I warmed up the car, opened the doors and the hood and turned it on. Like your car there are 2 lines with plastic screw caps running along the top of the drivers fender. What type of gauge do I need to check the pressure and do I hook it up anytime (car running, not running, ac on, ac off??)
John
justin 07-23-2001 07:49 AM
Hey guys Mine is a 83 944 and I really need to know where to charge and check the freon. Is it the lower one by the compressor or the one by the drier on top. i think i charge on the lower one and check it on the upper one? Am I right? help it's hot..........
Drive it like you stole it........Justin
scottewid 07-23-2001 08:51 AM
White, they're called a/c manifold gauges and you can get them at www.acsource.com. It's basically two gauges with three hoses. One gauge is calibrated only up to about 150psi and the other goes much higher for checking high side pressure.
You can get a cheapo single gauge at Pep Boys, but should get real manifold gauges if you're serious about doing your own a/c work.
You primarily use the gauges to check the low and high side pressures when the system is running. With the compressor engaged, generally, your low side pressure should be between 25- and 40 psi and high should be 150 to 230ish, depending upon outside air temp. If they're lower, you're undercharged and if higher overcharged. There's a whole bunch of other things that can cause screwed up pressures, though, so that's just a rough rule of thumb assuming everything else is working right.
Without the system running, the pressure in your r12 system should be about 60-80 psi, depending upon outside air temp. If lower than that, you're probably way low on charge and this is preventing the compressor from turning on. The cheapo Pep Boys gauge can tell you this (I even hooked a fuel pressure gauge onto the low side schrader before I got my real gauges.)
Justin, I don't really know about the early cars, but from what I hear, the one on the compressor is the low port where you should charge.
justin 07-23-2001 09:10 AM
Thanks Scottewid thats kinda what i thought too.
White951 07-23-2001 09:26 AM
Scott,
Sorry to keep asking???
If the low pressure side is low, how do I know how much r12 to put in. Do I just put some of the can in, and then test it again, or if it is down to a certain pressure then 1 lb or 2 lbs should be good?
John
Lawrence Coppari 07-23-2001 09:51 AM
The low pressure side should be between 20 to 30 psi while the engine is running with the AC blower on high and engine at about 2000 rpms and outside temperature 80 F. A flow through gauge is helpful here. I would charge a little, shut off valve on can to make sure you are getting AC system pressure. I would add refrigerant until gauge attains proper pressure. Or I would add until bubbles disappear in sight glass or until a thermometer in the duct vent of dash reads about 50 F. For substitute refrigerants, you cannot go by bubbles in the sight glass.
Pros evacuate system, then install recommended amount by weight.
White951 07-23-2001 10:02 AM
Scott,
Me again. Is the low pressure port that is used for pressure testing on the 86 951 also used for charging?
ae1969 07-23-2001 08:07 PM
I had my A/C converted to R134 this year cost me.....250 canadian (~170 U.S) including the recharge and everything....its not worth hunting for R12......
Take it to any A/C shop (don't bother with big names or dealers)......the little guys don't care if you drive a porsche or a pinto....they just want the business....
Its quick and painless.....and cooooooooooooooollllllllllllll !!!!
I forgot how nice A/C feels on a hot day.
Well worth the bucks.....
Alex
http://www.alta.net/944/alexs944na.jpg
The love of my life.......
Lawrence Coppari 07-24-2001 03:41 AM
Low pressure port - near the driver's side shock tower - is where you charge it. One is high press, one is low pressure. Obviously, charge the low pressure side. It is the one that gets cold. Charge with vapor, not liquid.
White951 08-03-2001 11:01 AM
I checked the pressure on my low and high side and both read NOTHING. What would be the reccomended action to take. Should I add 33.5 oz of r 12 as per the sticker inside the engine bay and then try to determine leaks or is possible to determine leaks first without charging the system. Also acsource reccomended autofrost since it was cheaper and oil is compatable and will mix ok.
Scott R 08-03-2001 11:56 AM
If you add 33oz of R12 that will be an expensive leak check! Use on can of 134 and some dye marker that will tell you right away. Then evac the 134 and dye marker, fix the leak then charge with the R12 or Autofrost.
idopps 08-03-2001 12:29 PM
hey, I did mine the other day. Your low end is on the compressor, which is by the altenator under the drivers side of the car. The high end is near the resivior with the window. Anyway. If you have a vacume, the cheapest way is to hook it to the high end and create a vacume in the system. Then shut the pump off and see if your pressure guage will keep pressure for a 10 minutes or longer. If the dial is moving with everything off, you have a leak. If there is not a leak and you decide to fill it yourself, just buy the new 134 and fill at the low end. The problem doing this, Porsche likes to may special problems so they can get paid to use special tools. The alternator is too close to fit a normal low end adapter on. If you unscrew that bar the is from the center of the under carriage to the compressor, it will move the compressor valve out of the way enough to fit it on. However, you will have to tighten it back up to get the compressor belt going, to suck to new freon in. Hope this helps!
diannone 08-03-2001 06:14 PM
its spelled vacuum and the EPA would just **** reading this board. :-)
idopps 08-04-2001 11:50 PM
Well, I could care less for the EPA. I majored in chemistry and will be a doc in 2 years and 3 weeks. They miss the point. They should not be so concerned about refringerant chlorofluorocarbons destroying a few O3 molecules, when there are billions of car engines runnig per day. Even if the hole in the atmoshpere could concretely be proven, they would still have a hell of a time trying to prove it is from exhast, let alone the minute amounts of CFCs in the air. Atmospheric an temperature shift has been recorded for many years. I think the EPA is about as effective as that supporter they had who lived in a tree for 4 years so it could not be cut down. What is worst? Cutting one damn tree, or speading diseases in the **** that lady took down the tree everyday? Its a total dumb ass thing ;-)
diannone 08-05-2001 12:24 AM
yes but it is the law.
check my next topic...
Allldi 08-05-2001 07:13 PM
Here is another great site about air conditioning. Check it out.
Ryan
1991 944S2 coupe
[This message has been edited by Allldi (edited 08-05-2001).]
