Don 944 LA's Avatar
Anyone tried the drilled Barn Door ??
Has anyone tried the drilled holes in the barn door of the 944 air meter ??
I came across some posts on a search and was reading about it, but it was quite some time ago.
I am curious as to any outcome of further discussions.
Don
1984/85 944na
Gold exterior / Black interior
Los Angeles / San Diego
Lookin for ideas etc...
Old 12-08-2003, 07:22 PM
SoCal Driver's Avatar
Why? The AFS is a balanced flow design. If you reduce it's movement you will make your fuel mixture leaner and burn up the engine.
Again: Why?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-08-2003, 07:56 PM
Don 944 LA's Avatar
In addition to drilling holes, one was also suppossed to loosen the spring. The end result was supposed to be more air without the computer changing the mixture or even knowing that there was more air .
Here's the link to the post
1984/85 944na
Old 12-08-2003, 08:09 PM
Doesn't work that way. While it may appear that the flap causes restriction is really doesn't. Changing an NA to a MAF doesn't make any noticeable difference in the NA's performance. Unlike a turbo.
Now the balistics of the door movement, overshoot, is something to think about.
I find it funny that some think turning the screw on the AFS will change the overall fuel balance. It only changes the fuel at an idle.
Also remember that running rich will whack the CAT. Then you could always run a straight tube AKA "test pipe".
Old 12-08-2003, 08:28 PM
I would rather install this:
""Air Filter Bypass Kit-
Many people replace air filters with high-flow versions for an extra few horsepower. We here at KaleCo have devised a much more efficient and more intelligent way of doing things. Pick up our air filter bypass kit and enjoy a nearly a free 15 horse power! Bypass that power-robbing and pesky air filter today, for much less than one of those "performance" air filters! Kit comes with everything you need to remove the air filter on most cars. KaleCo not responsible for mechanical failure after installing bypass kit. That's a pure coincidence. Kit can be used as many times as desired. Not for use on domestic cars, or cars using an exhaust tip less than a three inch diameter.""
Old 12-08-2003, 08:37 PM
Wolf1's Avatar
Man!!!! I gotta get one of those!!!...
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 12-08-2003, 09:31 PM
There is more:
www.kalecoauto.com
Old 12-08-2003, 10:07 PM
Wolf1's Avatar
There is more:
www.kaleco.com
Cool!!!! but I think this is the link you were thinking of..
http://www.kalecoauto.com
75 914 - Undecided.
Old 12-08-2003, 10:25 PM
