-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Fuchs value? (http://forums.pelicanparts.com/showthread.php?t=139864)
Rock 12-15-2003 08:59 PM
Fuchs value?
Hey guys
I have a set of those Fuchs black thingys on my 944. They look almost brand new, except with a little scuff on the back passenger side rim. Other than that, the chrome is all shiny and stuff and i cant find a flaw on them. How much do you think these things are worth? Are they worth more than the car?
justin 12-16-2003 12:53 AM
got any pics?
BlueQuestTSi 12-16-2003 05:14 AM
The Fuchs that seem to be worth the most are the matched set off of a 930 I believe. 16x8's and 16x9's, but even those aren't worth as much as the whole car, unless they were in perfect brand new condition and you happened to find the perfect bottomless checkbook buyer. Most of the Fuchs you see for sale go for prices anywhere between $300 for the set up to $2000+ for a set depending on condition and size.
The only ones I've seen that seem to be worth even more are the widenned ones, which wouldn't fit on the 944 anyways without some fiberglass wide fenders.
Dantilla 12-16-2003 09:00 AM
If they are the 7 & 8 x 15's that are pretty common on 944's, I recently sold a set for $600.
bertman 12-16-2003 09:25 AM
I bought a rough set of 16x7"s from Oklahoma Foreign for $400. After considerable labor stripping and polishing, I wouldn't sell them for less than $1500.
http://members.rennlist.com/cnalljr/IM000045a.JPG
Eric Mckenna 12-16-2003 09:49 AM
Re: Fuchs value?
Originally posted by Rock
Hey guys
Hey do you want to sell them .. what size are they . do you have any 7x16's.. I'll trade you some 6x16's or just outright buy yours to allow you to buy something else if you want to..
lemme know. I am about 20 minutes from you, so shipping isn't needed i can swing down and give ya cash...
e-mail me and let me know. or just reply to this thread.
eric.mckenna@huffybikes.comphone number is 937-704-5956
BlueQuestTSi 12-16-2003 10:02 AM
And by the looks of them, I wouldn't blame you. Good job, they look pretty sweet ;)
Rock 12-16-2003 11:58 AM
Here is a picture of them http://forums.pelicanparts.com/uploa...1071604685.jpg
As you can see they are a little dirty and wet
I think that stripped chrome above looks sweet! How much did that cost?
bertman 12-16-2003 12:09 PM
The Fuchs above are polished, not chrome. I refinished/polished them myself. I think companies like Wheel Enhancement will polish your wheels or exchange your set for polished set for around $1K, if I remember correctly.
Rock 12-16-2003 12:10 PM
bertman! where did you get that nose panel? that looks so cool
bertman 12-16-2003 12:23 PM
Sourced that header panel on eBay. IIRC, a lister here or on Rennlist had some 931 panels for sale a while back. You might want to search the classifieds or archives.
Macfreak007 12-16-2003 03:11 PM
bertman, i want to do you fuchs just like yours would you please explain the process in an email if you want, macfreak007@insightbb.com
bertman 12-16-2003 04:26 PM
Macfreak007, first take a look at some of the articles on the subject:
http://www.drivewerks.com/tech/techarticles_main.htm
I'll be glad to advise, if needed. It's not a particularly easy job but I think it's rewarding. Basically I stripped the paint, removed anodizing with oven cleaner (EasyOff!), smoothed the surface with 400, 600, 1000, then 1500 grit sandpaper and then polished and buffed to a jewel finish. After the wheels, you can do the caps and lugnuts. (most difficult part of the job... you might want to purchase these already done). I polish the wheels with Mothers every few months at the same time I wax the car.
Why don't you take pic's while you do yours and publish a tutorial?
Macfreak007 12-16-2003 05:13 PM
I might just do that, there are some out there but none totally complete, i have tried the oven cleaner to remove the anodonizationa dn it doesn't seem to work, how exactly did that step work for you? and what kind of oven cleaner did you use?
Macfreak007 12-16-2003 05:15 PM
wow bertman, i was just looking at your p-car online profile, your name is Carl too, that is my name when i'm not hiding behind this dumb alias
bertman 12-16-2003 05:53 PM
The trick on removing anodizing is to apply the EasyOff to the stripped wheel, let it work and bubble for a few minutes but don't let it dry. Then use steel wool and work on removing the anodizing. Rinse and Repeat as often as necessary. As you know, the stuff is very caustic but you'll want to remove as much anodizing by chemical means as possible. After the coat of anodizing is removed, the rest is relatively easy.
