Post swepco oil
I am changine the oil in my manual transmission. I was told that better oil will quiet rear diff noise. Do I need to spend $60 a gallon to get these results? Swepco oil was one mentioned are there any cheaper?
Old 08-22-2001, 05:42 PM
Send a message via ICQ to diannone
Post
i use amsoil
Old 08-22-2001, 05:55 PM
3sonfather's Avatar
Post
Try out:
http://www.*****************.com
SW201 for $38 / gallon
Old 08-23-2001, 04:58 AM
justin's Avatar
Post
Try (www.***********) their swepco is pretty cheap
Drive it like you stole it........Justin
Old 08-23-2001, 06:24 AM
Post
How often should the transmission oil be changed? differential?
Old 08-23-2001, 07:43 PM
Post
I use Mobile 1 synthetic oil in mine. 202,000 miles on my na 944 dailey driver and no noise. I believe it takes about 2 quarts (bad memory though) at about $9 per qt.
Old 08-23-2001, 07:49 PM
Post
SPEND THE $40.OO FOR THE SWEPCO 201........
YOU WILL BE PLEASANTLY SURPRISED BY THE
DIFFERENCE IT MAKES .......LESS NOISE
SMOOTHER SHIFTING........THE CAR WILL DEFINITELY BE QUIETER INSIDE............I WAS
SKEPTICAL TOO .............BUT NOW I'M A
SWEPCO BELIEVER.......TRY PERFORMANCE PRODUCTS I THINK IT'S ON SALE FOR 20% OFF NOW
Old 08-24-2001, 11:43 AM
Post
$38 dollars sounds like a deal will one gallon be enough?
Old 08-24-2001, 08:40 PM
Booster's Avatar
Post
It only holds a tad over two quarts, You don't need a gallon!
Old 08-25-2001, 12:16 PM
OEM OEM is offline
Post
Can you use the swepco in tranys that don't have a diff.?
Old 08-25-2001, 03:31 PM
