Red face Removing Cam Housing Bolt
Broke the end of a 6mm hex head wrench off in the bolt head of the last cam housing bolt. It was the kind that has a little bulb on the end and now that little bulb is in the bolt head. Not real tight, but too tight to come out with a magnet.
Any ideas how to get it out?
Old 01-06-2004, 03:15 PM
ae1969's Avatar
Send a message via ICQ to ae1969
drill it out......
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 01-06-2004, 04:14 PM
Sabyre's Avatar
Get yourself some Holy water, whole raw chicken, a live goat, a cow, a monk, a couple of nudie girls, some ky, nipple clamps... OH MY GOD WHAT AM I SAYING!!!
Yeah, try to drill it out, or maybe a punch.
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka
Old 01-06-2004, 04:22 PM
I've used all the cuss words I know and some that I made up but that can't really be understood. I hold Stuttgart responsible - why can't the little access hole be just 1mm larger?
Old 01-06-2004, 04:55 PM
gtroth's Avatar
What worked well for me: took the other bolts out, took cover off, and used a bolt extractor that fits over the part of the broken bolt that is still in the head (I used the #3 extractor from a Sears kit). Those bolts are expensive (for the 944S, ~$11 for the long bolts, ~$22 for the short). I also used antisieze on all the bolts when I put them back in.
I simply couldn't stomach drilling into my head, but that's me...
1995 993C4 guards red
1988 944S alpine white
Old 01-06-2004, 05:19 PM
AFJuvat's Avatar
Somewhere in the top 20 rules of auto repair says:
"Thou shalt NOT apply excessive torque to a fastener using a ball-hex wrench, for as surely as the sun arising in the morning, when yoyu do this to a critical bolt, the little ball tip will snap off and spread misery about the garage."
Thus it is written, so shall it be done.
In the short term, you are not in good shape right now. Your only option is to start drilling while not spinning the camshaft and having it crash valves into the top of your pistons.
Also note that Porsche supersceded that bolt - it is now a 10mm ZXN fastener (triple-square)
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-06-2004, 05:36 PM
Let's go shooting.
Dark Skies's Avatar
Any chance you could 'bounce' it out with little sharp taps to the side of the cap head whilst holding a magnet to it? Nothing heavy duty - just enough to vibrate it out. The side of a cold chisel or something with similar tensile resonance.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 01-06-2004, 05:49 PM
Crippler's Avatar
I suggest taking the cam tower off the car if it isn't already. It makes it much easier to drill out that bolt and it doesnt take very long to remove and the cam gasket is cheap.
1984 - Porsche 944
1994 Grand Cherokee
6inch Lift, 33" TSL'S
Old 01-06-2004, 09:15 PM
Since I did this same thing this past weekend. Tap a screwdriver against the piece that is stuck in there to loosen it up and then use a magnet. After busting my hex key I spent $30 on a set of hex sockets from Sears. If you stripped the inside you will have to extract it. I did one without drilling into the head.
Jason
Tryin to make a 944 work.....
Old 01-07-2004, 07:25 AM
TCMdocs944's Avatar
Something sticky and medium strength to the tip of the broken peice....
Insert it so it mates up with its lost end. Gently fish out???
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 01-07-2004, 08:25 AM
