Question Cold Start valve
I have good voltage at the plug to the cold start valve, gas pressure, and the cold start valve reads 4.6 ohms accross the contacts, suspision is that it is clogged. Am I missing anything?
Old 09-20-2001, 04:44 PM
Magnus_944's Avatar
Exclamation
I think 4.6 Ohm is way to low, around 30 Ohm is normal. That is for a 1983-1985 car.
/Magnus
Old 09-21-2001, 02:53 PM
Post
where is a cold start valve on a 944? The '83-'85 have an auxilarly air valve and the '85.5 and newer have a idle control valve. Both do about the same thing, let a little more air in for the more fuel the DME shoots in on a cold start.
Old 09-21-2001, 08:15 PM
