Composite Shop Owner, DJ
Oil in coolant. Removal?
Doing the head gasket on my 924. What is the best (easiest) way to remove the oily sludge build up from the coolant system once it is all back together?
'86 944, 5 Speed (Daily Driver) |
Little mice with little tooth brushes!
I used a coolant flush two times. Had suggestions of liquid dish soap. Still get a light film/scum after four or five flushes and a new radiator.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Where's nanotechnology when you need it!
As long as you are running cool, enjoy the extra waterpump lubrication.
03 Silver PT Turbo - Ours 86 White 951 - His 86 White 944 Manual - Hers 98 C-4 Sons 86 Gold 944 Auto - Sons 84 Maroon 944 Auto - salvaged 78 Yellow 924 - found a new home |
Just hope that the head gasket was the problem and not a crack somewhere deep in the block or head.
Don't normaly see a cracked head or cylinder unless there is a piston/rod failure. Just blows the head gasket.
But I think you want to do the oil cooler seals too.
i would much rather have oil in the cooling system than soap.
84 944 Non Alcoholic |
Liquid "Shout" Laundry soap.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
This is a 924 not a 944. 1979 model year. Does not have oil cooler.
